 | dual monitor setup
on Apr 28, 2011 at 3:41:26 am |
I have got ATI RADEON 5770 HD in my mac pro tower, I want to set dual monitors esp samsung B2430H 24' 1280*1080 LCD monitor, the problem is the card has only one DVI output... shall i use a DVI splitter... pls guide. Do i need another thing called MATROX DUALHEAD2GO
 | Re: dual monitor setup on Apr 28, 2011 at 6:39:06 am |
It has more than one output. One is DVI, but the other two are Mini DisplayPort. Just get a Mini Display Port to DVi adapter and you are good to go.
Shane
Read my blog,
Little Frog in High Def
