Log and Capture Problem
Mike Wilson
on Apr 25, 2011 at 10:51:40 pm
I am using FCP Log and Capture to record video from a wireless security camera (using Pyro A/V Link). It's connected via Firewire and records DV as a non-controllable device.
I am on a PowerPC Mac and recently upgraded from 10.4.11 to 10.5.8.
Ever since this upgrade (not sure if it has anything to do with one another), I noticed that my Log and Capture only shows a single still frame from my video source. It seems like it's frozen.
I have tested (and replaced) all the devices and cables. All hardware is 100% functional. So, I am left to believe that this issue has something to do with FCP alone.
Does anyone have any ideas as to what might be causing this and how to fix it? I am out of ideas.
David Roth Weiss
Re: Log and Capture Problem
on Apr 26, 2011 at 2:30:12 am
It seems clear that you updated the OS over the top of both the older OS and FCP. That's potentially a source of many problems. A full ground-up reinstallation is most likely the cure.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
A forum host of Creative COW's Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Mike Wilson
on Apr 26, 2011 at 5:46:55 pm
I can't believe that never crossed my mind :)
I re-installed and the problem has corrected itself.
