 | importing clips to fcp
on Apr 24, 2011 at 1:45:07 pm |
hi, I need your help i have a canon legria hf200, and i took all my clips from from the folder on the SD card and by doing that basically ruining the original structure of the card.
i've re-wraped with clipwrap
,and when I import them to fcp they play choppy and i cant share or export the sequence, fcp crushes. in output format the only other formats that are available except re-wraping, are dv and aic,
ProRes or ProRes LT are not available.
In both formats the playback is excellent, but when I try to add video transitions I get the error massage "there was insufficient media for the requested transion at one or more edit points." the duration of both clips is about 2 minutes/ plz help
 | Re: importing clips to fcp on Apr 24, 2011 at 8:49:37 pm |
It sounds like one of more of your edit points is at the end of the original media. You need to set your in and out points with at least a half second handle for the default transition to work.
Apple Certified Master Pro FCS 2
Sony EX-3
MacBook Pro
