Field Order for a PAL DVD project
David May
on Apr 16, 2011 at 7:08:34 am
Hi all
So there is a lot of information floating around about field order and the correct settings to use on this forum, but unfortunately im still coming up empty with regards to sending a project to compressor.
I have a 3.5 hour project that I want to render out as a quicktime file from fcp, compress into mpeg2 in compressor and put onto a dual layer dvd in DVDSP. Because the project is so long i cant really make any mistakes here seeing as time is of the essence.
My sequence setting is ProRes 422 1920x1080 25p, with the field order set to 'none'. I read somewhere that this was the best bet, am now wondering if i should have left it as 'lower'. Should my field order settings be different so that my dvd will play fine on both a tv and a computer?
I think ill cry if i discover my field order was wrong and i have terrible interlacing lines.
With that sorted, do you think that If i was to export this project as a self contained quicktime file using 'current settings', will there be any issues with encoding it onto a PAL DVD once ive used compressor to get it into MPEG2?
Ive got a lot of info about the best settings to use in compressor to get all that video onto 1 dvd so no so worried about that.
As always, the help is much appreciated!
Michael Gissing
Re: Field Order for a PAL DVD project
on Apr 16, 2011 at 9:04:38 am
The correct settings for PAL SD is interlaced and upper field for all codecs except DV. So if you have DV material in a ProRes422 SD sequence, set field order to upper and the shift fields filter on all the DV footage.
David May
on Apr 16, 2011 at 9:39:00 am
Thanks for the advice
none of the footage is SD though, most of it comes straight of a 5d MKII and is conformed to Prores.
Ill be making it SD once I run it through compressor, just wanted to know that if I leave the field order on the project as none, wont have any issues when I turn it into MPEG2
Rafael Amador
on Apr 16, 2011 at 9:47:12 am
[David May] "most of it comes straight of a 5d MKII "
Then you should have edited on a Progressive sequence, and deinterlacing the interlaced footage only.
rafael
http://www.nagavideo.com
David May
on Apr 19, 2011 at 1:48:22 pm
Thanks for the help!
All turned out very well
