I have a weird problem....
Anthony Shaw
on Apr 14, 2011 at 6:08:46 pm
Let me hear if you've ever had this problem and audio track in the time line but for some reason the sound goes off well before it should in the time line, I can hear it before it plays. I tried exporting it just to see if it would go into the final product and even there is starts early I have no idea why it does this can someone help?
William Carr
Re: I have a weird problem....
on Apr 14, 2011 at 6:28:18 pm
If you haven't yet, best to convert all your audio elements to FCP's favorite 48k 16 bit aiff, before adding to the sequence. This is quickly and easily done with Compressor.
If on a fresh sequence and you're using uniformly encoded audio as spec'd above, yet things begin to act quirky make sure you have performed a Mixdown of the sequence.
It's as simple as selecting all the audio elements on your sequence and from the menu bar choose Sequence>Render Only>Mixdown. If you change something after that, you may again hear weird playbacks. If so, trash your audio renders and Mixdown again.
Before a final export, I always trash all video and audio renders (Render Manager, under "Tools") and render everything fresh, including a Mixdown.
