Final Cut Pro 7 Shared Files Removed
Michael Mayer
on Apr 14, 2011 at 5:42:32 pm
Hey I was trying to remove my FCP serial number to put in a new one using FCS Remover but accidentally removed all the shared files instead of just the registration. Now my FCP won't open... I still have all the shared files in my trash bin but does anyone know how to get it working or where I might put the shared files so FCP can run again????
Thank you so much
Where we're going... we don't need roads.
Jon Chappell
Re: Final Cut Pro 7 Shared Files Removed
on Apr 14, 2011 at 5:51:01 pm
If you go to the Removed FCS Items folder in your trash, you can follow the file structure to see where the files were originally located.
For instance, if a file was located at /Users/myname/Documents/myfile.txt, it would be located at Removed FCS Items/Users/myname/Documents/myfile.txt.
My software:
FCS Maintenance Pack - Tools to keep Final Cut Studio running smoothly and fix problems when they arise
FCP Versioner - Backs up Final Cut Pro projects to XML and creates changelists for each revision
More tools...
Michael Mayer
on Apr 14, 2011 at 6:07:23 pm
I can only seem to see where the files are now... how do you see where they once were?? Thank you again
Jon Chappell
on Apr 14, 2011 at 6:16:07 pm
Here's a screenshot to show what I'm talking about. From looking at the file structure I can see that those files were originally located in /Library/QuickTime so all I need to do is drag them back there.
But you may find it easier just to reinstall Final Cut Studio.
My software:
More tools...
Michael Mayer
on Apr 14, 2011 at 6:19:07 pm
Thanks You!!!
Michael Mayer
on Apr 14, 2011 at 6:11:58 pm
I can only see where the files are now ie. /users/mike/desktop/removed fcs items/library. How do I see where they once where from this structure? Thank you again for your speedy response.
