FCP Multi-Clip Compressor Codec recommendation
John Scott
on Apr 13, 2011 at 9:57:40 pm
Hello, I would like to know if there is a "recommended ProRes422LT settings" when wanting to
use Compressor and limit the size of the output file and the time it take (2-6hours) for Compressor to change the codec.??. I have two formats that I want to make the same so I can use Multi-clip editing in FCP/.
The first file is 1440x1080 29/97 HDV 1080i60. The Second file is a 1920x1080/29.97/Apple ProREs422 file. Now I know I want to down convert the ProRes file to the 1440x1080 format. Right?
This is s for DVD release only.
I have been experiementing with ths setup
Description: Apple ProRes 422 with audio pass-through. Settings based off the source resolution and frame rate
File Extension: mov
Estimated size: 65.01 GB
Audio: multi-track passthrough
Video Encoder
Format: QT
Width: 1440
Height: 1080
Pixel aspect ratio: HD (1440x1080)
Crop: None
Padding: None
Frame rate: (100% of source)
Selected: 29.97
Frame Controls On:
Retiming: (Fast) Nearest Frame
Resize Filter: Linear Filter
Deinterlace Filter: Fast (Line Averaging)
Adaptive Details: On
Antialias: 0
Detail Level: 0
Field Output: Same as Source
Codec Type: Apple ProRes 422
Multi-pass: Off, frame reorder: Off
Automatic gamma correction
Interlaced (top field first)
Pixel depth: 24
Spatial quality: 50
Min. Spatial quality: 0
Temporal quality: 0
Min. temporal quality:
Is there a way to do this diffently without making my file sizes so HUGE? 50gig or so...
John Scott
Re: FCP Multi-Clip Compressor Codec recommendation/In addition.
on Apr 13, 2011 at 10:03:04 pm
One more question..
I have more files to Log and TRansfer. Is there a way to Log and TRansfer my media files so that they will end up matching for multi Clip Editing in FC? Hence skipping the Logging and Transferring time then taking them to Compressor to make all in the same format?
© 2018 All Rights Reserved
