 | How do i export apple pro res 4:2:2 from quicktime
on Apr 11, 2011 at 11:10:24 pm |
Hey Guys,
Basically i have a bunch of stills that i took that i am turning into a timelapse.
I am following the workflow listed here by phillip bloom.
http://philipbloom.net/2009/10/18/tutorial-on-how-to-turn-your-dslrs-stills...
I dont have an apple pro res setting when i export and try to change my video settings.
Anyone know where i can get the pro res codec's or plugins
 | Re: How do i export apple pro res 4:2:2 from quicktime on Apr 11, 2011 at 11:13:22 pm |
What version of FCP do you have.
**Hindsight is always 1080p**
 | Re: How do i export apple pro res 4:2:2 from quicktime on Apr 12, 2011 at 4:14:30 am |
Moreover, Image Sequences are a piece of cake in AE; just use the Interpret Footage commands properly for frame rate, and you're good to go.
Dave LaRonde
Sr. Promotion Producer
 | Re: How do i export apple pro res 4:2:2 from quicktime on Apr 12, 2011 at 5:22:11 am |
Converging a set of images to a video is super easy in QuickTime Pro. That and a lot of people do not have After Effects. I myself hardly do any motion graphics, let alone advanced motion graphics that would require AE.
The reason for asking what version of FCP Josh has was to find out if he even had the ProRes codec available to him. Seeing as ProRes is only available with cretin versions of FCP, and this is a FCP Forum
 | Re: How do i export apple pro res 4:2:2 from quicktime on Apr 14, 2011 at 7:41:31 pm |
Zane Barker: "ProRes is only available with cretin versions of FCP"
Now, there's no need for that.
