print to tape
Alexandre Brandt
print to tape
on Apr 11, 2011 at 6:20:39 pm
Hello all,
I've got Apple Pro Rez videos in 23.97, 29.97 and one PAL 25fps that I'd like to print to MiniDV tapes for archival.
Should I convert them all to DV 720x480 29.97 for the NTSC ones and in DV PAL 720x576 for the PAL one and then print to tape ? Is there a higher quality format I can use and still print to MiniDV tapes ? is HDV a good option ?
Thanks for reading !
Alexandre
motion pictures + storytelling = ?
-> FILMMAKING !
Zane Barker
Re: print to tape
on Apr 11, 2011 at 6:38:29 pm
[Alexandre Brandt] "I've got Apple Pro Rez videos in 23.97, 29.97 and one PAL 25fps that I'd like to print to MiniDV tapes for archival."
[Alexandre Brandt] "Should I convert them all to DV 720x480 29.97 for the NTSC ones and in DV PAL 720x576 for the PAL one and then print to tape"
If you do you will take a hit on the quality.
In the last few years, I've become a bigger fan of digital archives. Hard drives are cheep.
**Hindsight is always 1080p**
Chris Tompkins
Re: print to tape
on Apr 11, 2011 at 9:43:39 pm
Ah man, Mini-DV for archival??? That is a horrible way to go.
Make a Digital Master and put it on a couple hard drives.
Chris Tompkins
Video Atlanta LLC
Paul Jay
Re: print to tape
on Apr 11, 2011 at 9:56:48 pm
Just dont!!
Alexandre Brandt
Re: print to tape
on Apr 11, 2011 at 11:02:58 pm
Well I have Full Quality masters in a hard drive + a back up drive but I was thinking of a MiniDV in case.
-> FILMMAKING !
