Mocha track into fcp not working
David Schuurman
on Apr 8, 2011 at 2:44:18 am
Hi folks,
nice to be here. long time reader!
I have just started using Mocha for FCP and I have been tracking splines really well and inserting the mocha logo in to check how it looks and it all looks great.
My problem is when I export tracking data and bring it into FCP and paste the attributes to the graphic I want to use it's all wonky. sometimes its in a totally different section of the image, sometimes its just skewed improperly.
This is really getting me down because I get so excited when my project looks so good in Mocha but I cant do anything with it because the final step in FCP messes it up!
Is there any advice you can give? any steps I may be missing? suggestions?
I would really appreciate some insight here.
THanks so much.
David
Christopher Grimm
Any advice on getting rid of a lens smudge using Mocha 2.5.2??
on Jul 31, 2012 at 3:08:09 pm
Hi. I'm about to start cutting a 54 minute video down to around 8 minutes in FCP. Unfortunately there's a smudge on the middle of the lens and I cannot reshoot.
After Effects would be fairly laborious but may be my only option. I read that Mocha can do it better/faster.
Advice greatly appreciated!
I'd rather a full bottle in front of me than a full frontal labotomy...
Ross Shain
Re: Any advice on getting rid of a lens smudge using Mocha 2.5.2??
on Aug 2, 2012 at 4:51:46 pm
You might want to check out mocha Pro, which has a Remove Module that can assist in removing unwanted objects. It analyzes shots and can use the before/after frames to replace the object.
A few videos that may help:
Or
Good luck,
Ross
Ross Shain
Imagineer Systems
http://www.imagineersystems.com
Christopher Grimm
on Aug 3, 2012 at 1:45:58 pm
I have Mocha Pro.
Will give it a whirl!
Thanks for the advice.
