Delete extra final cut footage
Brian Evancic
on Apr 6, 2011 at 5:51:48 pm
I have clips in a sequence and I'm wondering if there's a way to cut all the extra footage that is still attached? So instead of having an in and out point and all the extra footage. It'll just be the clip that I need without the extra.
Chris Tompkins
Re: Delete extra final cut footage
on Apr 6, 2011 at 6:16:40 pm
You can use media manager.
You can select the part you want and create master clip.
You can export the part you want current settings make self-contained and re-import and delete old.
Chris Tompkins
Video Atlanta LLC
Cody Walters
on Apr 6, 2011 at 6:18:23 pm
What kind of media are you working with? I typically shoot P2 and when I bring the clips in via log and transfer, I only choose the clips I would be working with that are good. If I need extra, I go back and import the extra.
I suppose you could go to each clip, reveal it in the finder, open up quicktime and trim the excess. I never done this, and it sounds dangerous, but that's all I can think of.
Are you running out of disk space?
Cody Walters
Mac Pro 2.26GHz 8 Core
16 GB 1066 MHz DDR3
Final Cut Studio 3
Adobe CS5 Master Suite
Panasonic HVX-200
Canon 7D
http://www.codywaltersvideo.com
