anyway to copy exact same cuts/fx from one sequence to another?
Seth Marshall
on Apr 6, 2011 at 3:45:07 pm
I've just learned about nesting. In the past I've exported and then reimported to recut. This is lossy so I would prefer to use the nesting method but it would take forever to perform the exact edits on the new nested sequence.
Any way I cut just copy the EDL or something from one sequence to apply to another? thanks
Jerry Hofmann
Re: anyway to copy exact same cuts/fx from one sequence to another?
on Apr 6, 2011 at 3:51:54 pm
You can copy and paste any number of clips between sequences, does this help? i.e., copy the clips with their FX then paste them into another sequence.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Seth Marshall
on Apr 6, 2011 at 4:05:48 pm
thanks for the response Jerry.
What I mean is more about copying the edits from one sequence to another. My FX are mostly speed changes anyhow.
I've done a lot of little cuts that I now want to duplicate on my nested sequence (now that I've learned how to nest). This isn't for a portion of a sequence but an entire sequence altogether.
I had a final cut. Realized I needed to speed it up more by cutting out parts and making speed adjustments. So I exported and created a new sequence with the export. After spending many hours doing that I learned about nesting (DOH!) which would be the better way to do this. So I now want to do all edits from that first sequence and apply them to my newer nested sequence (instead of going through edit by edit and recreating them
Jerry Hofmann
on Apr 6, 2011 at 4:07:47 pm
You can copy a clip, then right click on any other clip to select "Paste Attributes". There you can add the filters etc you've used on the first clip. You could also simply copy the clip to the nested sequence. Open the nest, change it in any way, then it will be updated in the nested clip in your working sequence.
Jerry
Current DVD:
Seth Marshall
let me explain my situation better
on Apr 6, 2011 at 4:09:39 pm
sorry Jerry, I updated my last post with more info but you responded so fast! (thank you for that!)
This will help explain my situation better. It's not for a portion of a sequence that needs effects. It's for copying the cuts from an entire sequence.
Jerry Hofmann
Re: let me explain my situation better
on Apr 6, 2011 at 4:48:16 pm
You want to add EDIT points to the exported QT movie you then put into another sequence. and the cut points are what you want to add to the new sequence, right?
No easy way to do this I'm afraid.
You might copy the entire set of clips from that first sequence, then paste them to a higher track above the exported file, and add edits with the razor blade to match the length of the shots above...?
Jerry
Current DVD:
Seth Marshall
thanks
on Apr 6, 2011 at 5:16:49 pm
Thank you! That's what I needed to know. And now I know. I am realizing that exporting and recutting, so long as I stay in ProRes and am not doing FX (when I said FX I just meant speed), shouldn't really be lossy since it's referencing the source clips anyhow. thank you!
Marcus Samuel-Gaskin
Re: thanks
on Apr 7, 2011 at 5:10:53 am
What about Shane's tutorial?
Might be what you're after.
http://library.creativecow.net/ross_shane/fcp_copying-sequence-content/1
Seth Marshall
Re: thanks
on Apr 7, 2011 at 5:20:24 am
thanks for replying. I took a look but that wasn't was I was trying to do. Very informative though! I think what I was attempting isn't possible.
