 | Using ProRes 4444, won't let me render using 10-bit YUV
on Apr 6, 2011 at 3:41:03 am |
Hey guys,
I'm using FCP and my footage is ProRes 4444. I'm trying to render, but it tells me it can't find a codec, but when I switch to "Render in 8-bit YUV", it works... but now I can't render in 10-bit.
I'm using a macbook Pro. 8 gigs of ram. Latest version of FCP.
What can I do?
 | Re: Using ProRes 4444, won't let me render using 10-bit YUV on Apr 6, 2011 at 12:17:33 pm |
Can you open one of your ProRes 4444 clips in QuickTime 7 and export to Uncompressed 10bit QT from there?
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
 | Re: Using ProRes 4444, won't let me render using 10-bit YUV on Apr 6, 2011 at 2:29:12 pm |
Where did the 4444 footage originate?
 | Re: Using ProRes 4444, won't let me render using 10-bit YUV on Apr 6, 2011 at 2:39:28 pm |
5dtoRgb>after effects>fcp
It's 5d footage that stayed pro res 4444 through out
 | Re: Using ProRes 4444, won't let me render using 10-bit YUV on Apr 6, 2011 at 5:07:44 pm |
have you trashed your prefs?
is it a normal HD frame size?
