1920 x 1080 export with multiple channels of audio
Sean Anthony
on Apr 4, 2011 at 7:42:02 pm
I am trying to export out a film at 1920 by 1080 with 4 channels of audio. I realize I can only include the multiple audio channels if I export as Quicktime rather than Quicktime conversion. This means that I have to set my sequence settings to 1920 by 180 which is not an option in FCP 6. Is there something I am doing wrong or is there a work around?
Any advice would be much appreciated. Thanks.
Jeremy Garchow
Re: 1920 x 1080 export with multiple channels of audio
on Apr 4, 2011 at 8:47:35 pm
[Sean Anthony] "This means that I have to set my sequence settings to 1920 by 180 which is not an option in FCP 6. Is there something I am doing wrong or is there a work around?"
I would have to disagree. You can setup a 1920x1080 sequence in ProRes. What codec are you working in?
Jeremy
Sean Anthony
on Apr 4, 2011 at 8:56:20 pm
Hi Jeremy. I didn't know I can set up my sequence in 1080p. The footage was shot in DVCpro 720p60. So if I set my sequence to apple pro res than I can export in 1080p. Is that correct? Thanks.
Jeremy Garchow
on Apr 4, 2011 at 9:15:43 pm
[Sean Anthony] "The footage was shot in DVCpro 720p60. So if I set my sequence to apple pro res than I can export in 1080p. Is that correct? Thanks."
Whoa. This is different. What exactly do you have to deliver?
Sean Anthony
on Apr 4, 2011 at 9:17:22 pm
I need to deliver a quicktime in 1080p with 4 channels of audio.
Jeremy Garchow
on Apr 4, 2011 at 9:33:42 pm
Frame rate?
Sean Anthony
on Apr 4, 2011 at 9:35:28 pm
Our frame rate is 23.98
Jeremy Garchow
on Apr 5, 2011 at 3:18:57 am
You can compressor to cross convert. Make sure to set the frame rate as custom and 23.976 (not 23.98).
If you have a Kona, it will cross convert in real time from 720p23.976 to 1080sf23.976.
Neil Sadwelkar
on Apr 5, 2011 at 11:02:20 am
You can have 4, 8, 12, 16 channels in QuickTime out of FCP. Broadcasters have begun taking multiple-channel QuickTime ProResHQ 1080 files as submission now.
You need to set your sequence to have 4 channels. Then in sequence settings, go to the Audio output settings and set the sequence to 4 channels set as 2 stereo pairs or 2 dual mono pairs as needed.
Then, in the timeline, to the extreme left you can right-click and assign each track to it's corresponding number output from the drop-down. Ch 1>1, Ch 2>2, Ch 3>3, Ch 4>4.
Now, when you do a File > Export > QuickTime, you will have a QuickTime movie with 4 audio tracks in it.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
