Channel split
john wilkz
Channel split
on Apr 4, 2011 at 6:43:21 pm
Hi im new to the software... and i was wondering how i would go about isolation specific channels on a peice of clip... e.g. remove or isolate RGB colours... the effect im tryna go for is the anaglyphic look..
i have seen this tutorial for photoshop
so i thought i could transfer the method to final cut.. help would be appreciated e.g. if theres a better way... or the above if it would work.
thanks
Cody Walters
Re: Channel split
on Apr 4, 2011 at 7:27:02 pm
I'm not sure how you re-create this in Final Cut, but you could import your video clip into Photoshop and do this. I'm not sure if you can export out a video file from Photoshop. You may need to use a combination of Photoshop and After Effects. Maybe someone else has a better idea. Richard Harrington has a tutorial using Photoshop for video. Might want to check that out.
Cody Walters
Mac Pro 2.26GHz 8 Core Xeon
16 GB 1066 MHz DDR3
Final Cut Studio 3
Adobe CS5 Master Suite
Panasonic HVX-200
Canon 7D
john wilkz
Re: Channel split
on Apr 7, 2011 at 4:20:24 pm
Thank you response is appreciated..
will try that out
cheers.
