cropping + maintaining quality
Ken Tannenbaum
on Apr 4, 2011 at 2:55:16 pm
Hello...I shoot 1080p. I've got a clip I'd like to enlarge and know how to crop it in FCP but wonder what parameters there are for maintaining quality. I'm new at this part of working with video. Can I assume that, as an example, if I crop to double the size, I'll end up with a video that's essentially half the frame size? Obviously unsure of the relationship.
Thanks.
Ken Tannenbaum
Shane Ross
Re: cropping + maintaining quality
on Apr 4, 2011 at 3:17:38 pm
The most you can really blow up any image without real visible quality loss is 10%...15% if you push it. No way can you push something to 150% and expect to retain the quality you have at 100%. Even at 1080p.
Shane
Ken Tannenbaum
on Apr 4, 2011 at 3:25:43 pm
Appreciate the advice.
Ken Tannenbaum
Bret Williams
on Apr 4, 2011 at 4:17:01 pm
Placing 720p in a 1080 sequence is a 150% enlargement and it looks fine. When dealing with progressive in HD you can get away with much more than the old Interlaced days.
Shane Ross
on Apr 4, 2011 at 4:39:42 pm
[Bret Williams] "Placing 720p in a 1080 sequence is a 150% enlargement and it looks fine."
Eeeeeh....they look a little soft when you do that.
Shane
