Workign between FCP and AE
olaf steel
on Apr 1, 2011 at 11:23:46 pm
I'm doing an offline edit in FCP and will need to do some after effects. I was wondering what the best method for this would be. If possible, I would like to keep my file sizes small between projects to keep render times as quick as possible.
Can I somehow bring an XML film from FCP to AE, and then back to FCP to put the project online again?
Keep in mind I have never worked with XML files, so if this is the solution, please give me easy to follow instructions.
Thanks in advance for any help with this.
Jeremy Garchow
Re: Workign between FCP and AE
on Apr 2, 2011 at 3:12:42 pm
With automatic duck you can get your timeline to AE, but not back. From AE you would render out a qt movie and place in your fcp timeline.
You want pro import AE.
© 2018 All Rights Reserved
