HDV/HD to DVDsd: real poor quality
gabriele gismondi
on Mar 29, 2011 at 5:02:21 pm
i've looked deeply in the forum to look for some helping, but i found out that many people have my problem..
From a PRes (from HDV material)8-bit sequence, i'm trying to get the best quality version on DVDsp (my video will be 15 minutes..very nice on FCP).
I've gone through (always using default settings, except increased bitrate values, frame controls ON, best quality encoding on DVD Studio):
1-direct output on QTmovie to DVD STudio
2-Sequence sent to compressor (90minutes best), than to DVD Studio
3-direct output on QTmovie to Toast.
4-direct output on QTmovie to Compressor than to DVD Studio
Always get poor quality, texts are pixelated, no HD detail keeped.
I'm alittle depressed..the only thing i still dind't tried is to copy my sequence to a PalDv 16:9 sequence and that export from there..but i'd love to hear from you first..
tnx
Shane Ross
Re: HDV/HD to DVDsd: real poor quality
on Mar 29, 2011 at 5:12:24 pm
[gabriele gismondi] "Always get poor quality, texts are pixelated, no HD detail keeped."
Because DVDs aren't HD quality, they are SD. If you want HD quality, you need to invest in BluRay options.
Shane
Chris Tompkins
on Mar 29, 2011 at 7:05:51 pm
Out put your video from the FCP Sequence using "current settings"
drop that into compressor.
Like you have, frame controls on best. Bump up the data rate.
Won't look as a good as HD but still should look decent.
What's your highest data rate used?
Chris Tompkins
Video Atlanta LLC
Pradip Patil
on Mar 29, 2011 at 7:33:22 pm
You can also try using iDVD. Make sure u select high quality from preferences.
I got very good quality results for HDV content using iDVD.
Pradip Patil
Mumbai,India
Paul Jay
Re: HDV/HD to DVD: real poor quality
on Mar 29, 2011 at 8:03:43 pm
Edit your compressor dvd preset.
You must use the resize filter in frame controls.
It will give you descent SD quality.
But it still will suck on a HD screen.
Hdv to dvd played on HD screen= no go.
gabriele gismondi
on Mar 29, 2011 at 8:02:26 pm
hi thanks for tips.
i usually set 2 pass vbr average 6,5 max 8,5, then go for encoding.
still can't get un-pixeled texts--
of course i know sd dvd is not the same than bluray disc, but i'll be glad to get something better out using HDV clips than using sd clips..
Chris Tompkins
on Mar 29, 2011 at 8:27:12 pm
Hummm, care to post a pic of your text here?
As you may know, thin text does not hold up well.
Chris Tompkins
Video Atlanta LLC
Paul Jay
on Mar 30, 2011 at 1:00:21 pm
what is even better is change your HDV timeline to a ProRes Timeline.
This will improve text, graphics etc.
Export quicktime with current settings from FCP.
Then use compressor DVD preset with Frame controls ON
Resize filter to BEST.
Then Burn in DVD Studio Pro.
John Doggett-Williams
on May 9, 2012 at 10:23:18 pm
Hi Gabriele, did you ever find a solution to the HDV problem? I'm experiencing the same thing now. It's frustrating not to be able to get the same quality as the QT movie on a DVD.
http://www.fineeyeproductions.com
Craig Alan
on Apr 1, 2011 at 3:43:39 pm
http://www.kenstone.net/fcp_homepage/hdv_timeline_to_sd_dvd.html
OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz
; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP certified; write professionally for a variety of media; teach video production in L.A.
gabriele gismondi
on Apr 1, 2011 at 5:50:11 pm
tnx a lot to anyone who answered, ive been out for work for a few days..now i'll try your tips.
gabriele
gabriele gismondi
on Apr 2, 2011 at 2:27:15 pm
Hi
i'm trying your ways but cannot get any improvemnts in final dvd quality from my HDV clips.
I've noticed tis: i've imported HDV clips via fireway, auto-conversion to ProRes, so i have a prores timeline with prores files. The fact is that i've always set Render controls (in Seq settings) to 8bit and not 10bit/YUV. Should it be changing the quality of the final QTmovie to put into Compressor/DVDS changing this setting to 10bit/YUV (i get right now that ProRes is 10bit..not 8 bit)?
tnx
gabriele
Michael Pfost
on Apr 2, 2011 at 6:30:00 pm
I've always found that the key is to resize the video properly using Compressor and "Frame Controls." Using default settings or the FCP timeline to resize will give very poor results.
