Direct to edit facility
Robert Wrensch
on Mar 28, 2011 at 12:50:45 pm
I have an HD broadcast van. I send a production signal into AJA hdtv distribution amp. It then patches into black magic up cross down converter , i set it to Pal SD Letterbox. The sdi out then goes into the blackmagic deck link studio for final cut pro. I am struggling with the settings in fcp and black magic to get a SD 16x9 out onto timeline. Audio no problem, HDTV 1080i 50 no problem. Can anyone help with this.
Tom Brooks
Re: Direct to edit facility
on Mar 28, 2011 at 3:04:54 pm
What is the unsatisfactory result you are getting? If you set the downconvert to PAL SD Letterbox, sounds like you'll get 4:3 with letterbox. Can you set to PAL SD 16:9 Anamorphic?
Bouke Vahl
on Mar 28, 2011 at 5:55:52 pm
I'm with mr Ixus here.
(That is what is is in your picture, right?)
Bouke
http://www.videotoolshed.com/
smart tools for video pros
