Log and Transfer Problem
ben smallzman
on Mar 26, 2011 at 7:17:35 pm
I cant log and transfer any clips at all. My Nikon S8100 doesnt get recognized in the log and transfer window, so i imported the clips into iphoto and then tried dragging the clips into the L&T window. but it kept saying, "contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media." After that, i converted the clips to Apple Prores 422 via Compressor, and then tried dragging those into the L&T window. the same messafe popped up. so clearly, i cant get any clips into the log and transfer window. Can anyone help?
Thank you
Steve Eisen
Re: Log and Transfer Problem
on Mar 26, 2011 at 9:23:11 pm
You found out the hard way that you can not log and transfer files from that camera. Not all cameras are supported.
You have 2 options. Use Compressor or MPEG Streamclip to convert to ProRes.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
ben smallzman
on Mar 27, 2011 at 1:43:59 am
i had already used Compressor to convert the clips to prores 422 and these still did not work.
Shane Ross
on Mar 27, 2011 at 2:21:05 am
After you convert to ProRes, you DO NOT need to use Log and Transfer. Just import them.
Shane
ben smallzman
on Mar 27, 2011 at 12:03:02 pm
oh ok, thank you
