Sequence line missing and linking clips... Please
Howard Shooter
on Mar 23, 2011 at 7:10:27 pm
I am fairly new to fcp with a couple of probably basic questions. I have been filming about 15 shorts and when I open one specific sequence up the sequence line is missing. Under the window tab it says it's open but the time line isn't there.
Apologies if this is a stupid question... Also...
Is it possible to link the clips in fcp so I can change the exposure as a grouped set, not always having to do the changes to individual clips?
Howard
Jeff Greenberg
Re: Sequence line missing and linking clips... Please
on Mar 23, 2011 at 9:27:55 pm
[Howard Shooter] "I am fairly new to fcp with a couple of probably basic questions. I have been filming about 15 shorts and when I open one specific sequence up the sequence line is missing. Under the window tab it says it's open but the time line isn't there."
I think the window is closed... - hit CONTROL U (window>arrangement)
Or...that you've scrolled up in the sequence window. Check that too.
[Howard Shooter] "Is it possible to link the clips in fcp so I can change the exposure as a grouped set, not always having to do the changes to individual clips?
Fix the first one. Copy. Edit> paste attributes. Make sure your check the filter checkbox.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
