Multiple codecs issue
Rick Pratt
on Mar 23, 2011 at 3:38:31 am
So I am posting a movie that was shot on four different cameras with 4 different codecs - h264, XDcam, DVCPro HD and ProRes 422 (HQ). The initial idea was to convert all to ProRes 422 (HQ) and then merrily go about our day. Now I am discovering that the XDCam and DVCPro HD footage all playback pretty nicely in a ProRes sequence. I'd love to not have to spend the time converting the XDCam and DVCPro HD footage to Pro Res, but am I going to run into issues at the end of the post process, such as anomalous glitches and render problems due to the mixed codecs?
Chris Tompkins
Re: Multiple codecs issue
on Mar 23, 2011 at 11:48:36 am
If it continues to play fine and you can edit, it's worth a shot.
When you do a final RENDER ALL though, it will compress to the codec of the sequence.
Chris Tompkins
Video Atlanta LLC
Chris Borjis
on Mar 23, 2011 at 4:09:34 pm
As long as the framerate is the same it should work quite well.
Set the render codec in the sequence setting to ProRes for best results.
