producing .avi files with xvid compression
Suzanne Howard
on Mar 22, 2011 at 10:55:45 pm
I have been asked to supply a file to a client as an .avi with xvid compression (it will be displayed on a large sports screen). The project is a re-edit of an video artwork that was originally intended for projection in a gallery.
I have trawled through the net trying to find the best way to do it via FCP and quite frankly it has just left me confused.
It seems the xvid codex is not yet available for mac??
I have written to the client's tech people asking if DVIX compression is okay as well?
Any help would be appreciated
Suzanne
Rafael Amador
Re: producing .avi files with xvid compression
on Mar 22, 2011 at 11:49:03 pm
Hi Suzanne,
You need a QT xvid export component.
Have a look here:
http://www.apple.com/quicktime/resources/components.html
Then you should be able to export as avi with the codec of your choice.
rafael
http://www.nagavideo.com
Suzanne Howard
on Mar 22, 2011 at 11:54:44 pm
Thanks very much for your quick response Rafael. Will do so.
Have finally made contact with the clients' tech team - am producing an .avi file first - hopefully it may not need compression,
Regards
Suzanne
