Brightness Adjustment?
Jim Reed
on Mar 22, 2011 at 6:57:59 pm
I have a 35 second video I'm looking over and it would be a really good video if I could brighten up the entire video a little. The only light in the video is from several car head lights on a particular area. I can see the people in the area fine, but it just needs to be brightened up a little bit more.
How do I do this?
Jerry Hofmann
Re: Brightness Adjustment?
on Mar 22, 2011 at 7:02:55 pm
Add a Color Corrector 3-way filter to the clips. Then slide the sliders under the three color wheels until you get your results.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Jim Reed
on Mar 22, 2011 at 7:23:57 pm
Thanks for the quick reply.
I'm working with the sliders on Color Connector 3-way but see no changes being made. Obviously I'm missing a step here.
Thax Clave
on Mar 22, 2011 at 7:37:19 pm
After you drop the filter onto the clip, you need to "double-click" that clip into the Browser window.
Then, you can see the adjustments.
Jim Reed
on Mar 22, 2011 at 7:39:34 pm
Thank you. That did it.
Thax Clave
on Mar 22, 2011 at 7:44:02 pm
Even after well over half a decade of editing FCP,
I still sometimes get caught by that one.
