replacing proxies, sequence problem
Naomie Ross
on Mar 19, 2011 at 2:04:14 am
I made an edit of footage I shot on a 7D. In order to work faster I made half size files of all my clips and edited using that.
Now I am done and want to replace the proxies with the original clips.
So I made a new sequence with the settings I needed them to be and then I reconnected the media of the proxies to the original full size files.
When I copied and pasted the edit from the old sequence into the new one, everything came in HUGE for no apparent reason.
If I drag a clip from the browser into the sequence, it's fine. It's only if I copy and paste the clips from the old sequence.
Naomie Ross
Re: replacing proxies, sequence problem
on Mar 19, 2011 at 3:50:53 am
ok I figured it out. For each clip I opened up the motion tab and they were all at 200% scale, so I put it back to 100%. I still don't know why that happened to begin with, but at least it's fixed.
© 2018 All Rights Reserved
