Creative Cow "VIDEOS-REELS" Upload Failure?
Daniel Monskey
on Mar 18, 2011 at 9:37:36 pm
I have been attempting to upload a short video to the Creative Cow "VIDEOS - REELS" page and failed with every attempt and every format. It is a 960 x 720 59.94 fps 3:29 minute video. I am outputing through FCP 7.0.3 using Quicktime Conversion. I set it to the H.264 setting and I've gotten it to a manageable size (less than 500MB---455MB). After a few hours of "loading" a message comes back "No file found in upload". I have output this same file using "Program Stream.mpeg" (408MB), which I thought was an acceptible format.
Any suggestions to get this video to successfully upload? I had this same problem months ago and finally gave up. I attempted more format variations at that time and failed with all, so I am loosing faith with failure coming so regular. I would really like to post this and get feedback from the CC community.
Dan
Daniel Monskey
Stephen Smith
Re: Creative Cow "VIDEOS-REELS" Upload Failure?
on Mar 18, 2011 at 10:10:36 pm
There is a demo reel forum that is the place to post this question: http://forums.creativecow.net/demoreels
500mb sounds really big to me. How long is this video?
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Daniel Monskey
on Mar 18, 2011 at 10:31:09 pm
It may seem big, but the VIDEOS/REELS pages says tha tis the max acceptible size. It is a 3:29 minute piece. It doesn't have ".H.264" as an ending, but the format is in that form. The other does have the ".mpeg" in the title.
Dan
Daniel Monskey
Daniel Monskey
on Mar 18, 2011 at 10:33:04 pm
I did not see the "Demo-reels" forum. Overwhelmed by the variety. I posted there now.
Thanks for the suggestion and help.
Dan
Daniel Monskey
Rafael Amador
on Mar 18, 2011 at 10:36:55 pm
[Daniel Monskey] "3:29 minute video."
Hi Daniel,
500 MB for a 3' 29" video clip is simply CRAZY.
That data-rate is huge for any H264 or MPEG-2.
Which data rate are you setting?
Which K-frames are you setting?
rafael
http://www.nagavideo.com
Daniel Monskey
on Mar 18, 2011 at 11:41:26 pm
From FCP I "export using QT Conversion"
Leave the setting at QT Movie
Compression Setting is: H.264
Compressor quality is at "Medium"
Key Frames is; Every "24" frames
Encoding: Best quality (multi-pass)
The Dimensions are set to 1280x720 (1248x702)
Audio is Integer 48.000kHz 16 Bit Stereo
"Prepare for internet Streaming (Fast Start)"
On a 3' 29" video it compresses an output file of 455.1MB.
That is the settings. I always try to maximize my quality since I hate the pixelating at lower quality.
Perhaps I need a lesson on output procedures.
Dan
Daniel Monskey
Rafael Amador
on Mar 18, 2011 at 11:59:09 pm
[Daniel Monskey] "From FCP I "export using QT Conversion"
OK.
Move the Quality Slide to High and set:
- Key-frames: AUTO.
- Data-rate: "Restricted to: 12.000 kbps".
- Set the audio to AAC (256Kbps) instead of PCM.
Export and your movie will look great and much lighter.
rafael
Daniel Monskey
on Mar 19, 2011 at 12:25:31 am
Wow Rafael---Thanks for the help!
How can I learn how to make all the different settings and adjustments and which compressions to make? If I don't do this all day every day it seems like a lot to learn for the varying needs and uses. What would be the most helpful source from which to learn?
Dan
Daniel Monskey
