FCP damaged file
Javad Ahmadi
FCP damaged file
on Mar 16, 2011 at 7:51:38 pm
Hi Guys;
I have FCP 7.0.3 file which got corrupted. Now when I try to open my Final application crushes. Is there any way I can recover. Please advise.
Javad Ahmadi
Alive ProStudios
Frank Nolan
Re: FCP damaged file
on Mar 16, 2011 at 8:08:39 pm
[Javad Ahmadi] "I have FCP 7.0.3 file which got corrupted. Now when I try to open my Final application crushes. Is there any way I can recover."
You need to be little more specific. Is the file you are talking about a session file or is your application corrupted?
Can you open the FCP application from the FCP icon in your applications folder?
Javad Ahmadi
on Mar 16, 2011 at 8:14:27 pm
Thanks Frank.
The application works just fine. There is no problem with other FCP files I have. When I try to open this particular file, the application crushes.
regards
Javad Ahmadi
Alive ProStudios
Frank Nolan
on Mar 16, 2011 at 8:22:24 pm
Try launching the FCP from the icon in the apps folder then going file>open>your project, and see if it open from within FCP.
If that doesn't work try going to the autosave vault and see if you can open the latest version in there.
Javad Ahmadi
on Mar 16, 2011 at 8:28:03 pm
I already tried that. I tried it on a separate computer, same application crush happens. I sent it to a friend. The file crushed his application.
Do you recommend FCS Maintenance Pack? Do you think that might fix my problem.
I appreciate your advise and assistance.
thanks
Javad Ahmadi
Alive ProStudios
Shane Ross
on Mar 16, 2011 at 8:34:51 pm
I HIGHLY recommend the Maintenance Pack. There is a PROJECT REPAIR app in there that does wonders.
Shane
Javad Ahmadi
on Mar 16, 2011 at 8:40:52 pm
Thanks Shane and Frank.
I just purchased it.
I will let you know how it goes.
kindest regards
Javad Ahmadi
Alive ProStudios
