compression and standards conversion
Rob Dunford
on Mar 16, 2011 at 10:39:35 am
I know this is quite the right forum for Compressor, but I figured the experts here would be more able to answer the question.
I use Compressor to convert 30 minute programmes from NTSC HD to PAL HD.
I set the duration to 100%, but the actual PAL duration is off by 3 frames.
I know it's not the DF/NDF issue, it's not a big enough error.
So...please....what gives??
Rafael Amador
Re: compression and standards conversion
on Mar 16, 2011 at 10:55:03 am
Are you spotting that difference on Final Cut?
I won't trust QT to see that.
rafael
http://www.nagavideo.com
Rob Dunford
on Mar 16, 2011 at 11:00:59 am
No, I am spotting this in Compressor and FCP.
Alexander Kallas
on Mar 17, 2011 at 10:33:35 am
Have you missed using the frame controls tab?
Cheers
Alexander
