Most practical method to convert from ProRes to AVCHD
Michael MacInnis
on Mar 16, 2011 at 1:11:37 am
Hey everyone,
I have an FCP edit that uses ProRes encoded footage. I would like to know the quickest and most efficient method to get from FCP to an AVCHD file (preferably .m2ts or .mkv). Thanks.
Michael
Jeremy Garchow
Re: Most practical method to convert from ProRes to AVCHD
on Mar 16, 2011 at 2:48:11 am
An avchd recorder? What exactly are you trying to do?
Michael MacInnis
on Mar 16, 2011 at 3:27:29 am
I want to convert/render my FCP project to an AVCHD file (such as .m2ts or .mkv). I know that FCP can't do AVCHD natively so I'm looking for the best method to get from point A (my FCP edit) to point B (the final AVCHD) while maintaining the quality as much as possible.
Jeremy Garchow
on Mar 16, 2011 at 3:34:33 am
But please tell us where that avchd file is going.
Thanks.
Michael MacInnis
on Mar 16, 2011 at 3:51:33 am
Sorry, it will be burned to a Blu Ray disc.
Paul Jay
on Mar 16, 2011 at 8:14:43 am
Why use avchd then?
Dont see any reason.
Rafael Amador
on Mar 16, 2011 at 8:21:20 am
[Michael MacInnis] "Sorry, it will be burned to a Blu Ray disc."
You should have started by there.
You can use Compressor to convert your movie to H264 or MPEG-2 Blu-ray compliant.
Then you will need Toast, Adobe Encore or similar to author the disk.
Search for Blu-ray in this forum.; you will find all the info.
rafael
http://www.nagavideo.com
Chris Tompkins
on Mar 16, 2011 at 12:10:52 pm
Also,
File:Share function will create BD files for you from your sequence.
Chris Tompkins
Video Atlanta LLC
Michael MacInnis
on Mar 16, 2011 at 4:46:01 pm
Thanks for the reply guys. I've give those a try.
