Replacing Clips
Jack Morgan
Replacing Clips
on Mar 15, 2011 at 7:25:28 pm
I often do spots in English then in Spanish. In my old system I could duplicate the time line and replace the clips one by one with Spanish replacements; and keeping the original clip attributes. Is there a way to do this in FC ? I've been searching around and haven't found anything. Thanks, Jack
jmorgan
DeadLine Productions
Houston, Texas
Rob Schultz
Re: Replacing Clips
on Mar 15, 2011 at 7:55:14 pm
After you overcut your new clips, select and copy (cmd-c) the original, then select the new clip and choose 'paste attributes' (opt-v). You can see in the paste attributes dialogue exactly what you'll be applying. Also, you can apply one set of attributes to many clips at once with this method.
Rob Schultz
Better Radio is a comedy podcast. In space. And iTunes!
Jack Morgan
Re: Replacing Clips
on Mar 16, 2011 at 4:31:34 pm
Thanks for your response. I'll try it. Jack
jmorgan
Houston, Texas
