Import highest quality from SD card
Phil Huizen
on Mar 15, 2011 at 6:46:20 pm
Hello there, I have a TZ7 wich I use to record video. I would like to know what gives the highest quality: Log & Transfer to Prores 422 directly from the memory card (with directory structure intact) or just drag and drop the .mov files? (Yes, I know I should not use H264).
Thanks alot,
Phil Huizen
Chris Tompkins
Re: Import highest quality from SD card
on Mar 15, 2011 at 8:29:33 pm
Your quality settings come from the camera when you record.
L&T does not set quality.
Check out Shane's Tapeless Workflow Tutorial here on the cow.
Copy your SD card in its entirety to the local hard drive. Back it up.
L&T into the edit using ProRes 422.
Edit.
Chris Tompkins
Video Atlanta LLC
Shane Ross
on Mar 15, 2011 at 9:41:04 pm
This one...
Tapeless Workflow for FCP 7 Tutorial
Shane
Chad Brewer
on Mar 16, 2011 at 12:24:33 am
Hey Shane,
Have you kept track of how many times you've pasted this link?
Perhaps you've written a keyboard shortcut for it by now...
All the best man...
Chad Brewer
Senior Broadcast Videotape Operator
TeleVersions, LLC
Phil Huizen
on Mar 18, 2011 at 9:27:53 am
What is the use then of the files and directorys on the card when the quality is not touched when only copying the .mov's?
Rafael Amador
on Mar 18, 2011 at 10:41:05 am
[Phil Huizen] "What is the use then of the files and directorys on the card when the quality is not touched when only copying the .mov's?"
The structure is important, for example, if you want to relink to the original files.
Your camera files has no native TC; for all Media Managing is better to work with the original file structure.
rafael
http://www.nagavideo.com
