Glitch occurs after every Transition
Matt Gussin
on Mar 15, 2011 at 1:45:10 pm
Hey, I am doing some work in Final Cut Pro and whenever i apply any kind of transition (fade, wipe etc) a glitch occurs on the last frame of the transition; what happens is that the frame seems to jump so for example when someone is speaking and waving his arm, you will see the person waving their arm again - if that makes sense - so basically, the frame jumps which makes it look a lot less professional..
Any help please? - i have searched the forums but could not find any answers?
Michael Kammes
Re: Glitch occurs after every Transition
on Mar 15, 2011 at 4:33:46 pm
What kind of footage are you transitioning to and from, and what are your timeline settings? Are you in Safe or Unlimited? Are you rendering the effect?
I am assuming that you have plenty of heads and tails for the transition? Try taking 2 longer shots, and trimming a bunch of the top and tail, and trying a transition, and see if it still happens.
Sounds like a transition between 2 Long GOP files, and the wrong I-Frame is being referenced during playback. This is just speculation without more info.
~Michael
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michaelkammes.com
.: twitter: @michaelkammes
.: facebook: /mkammes
Hear me pontificate: Speaking Schedule .
