Video Processing
Farrokh Kouchekpour
Video Processing
on Mar 15, 2011 at 11:23:54 am
Hi Guys,
I am doing an offline for a short film that was shot on the RED One. The DP converted the clips into Prores HQ files and shoved them on a hard drive for me.
Now, is it worth setting the Video Processing to 'Render 10-bit material in high-precision YUV" or am I better off just setting it to 8-bit YUV?
Many thanks
Farrokh
Rafael Amador
Re: Video Processing
on Mar 15, 2011 at 4:34:40 pm
Hi Farrokh,
If your sequence is Prores, by default the render is set to 10b.
Should be like that.
If you render Prores at 8b YUV, you crunch the quality of the picture, but not the file size.
You'd get something like DV50, enveloped on a 10b file.
rafael
http://www.nagavideo.com
Michael Kammes
on Mar 15, 2011 at 4:38:07 pm
If it's an offline, then no reason to go high precision, right? You'll be conforming to the R3Ds later and coloring those, correct?
~Michael
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michaelkammes.com
.: twitter: @michaelkammes
.: facebook: /mkammes
Hear me pontificate: Speaking Schedule .
Rafael Amador
on Mar 15, 2011 at 5:27:44 pm
You are right Michael.
I missed the point of the off-lining.
rafael
Farrokh Kouchekpour
on Mar 15, 2011 at 8:06:25 pm
Yeah, that's correct. I'll render at 8-Bit then.
Thanks for the replies guys. :)
Farrokh
