Final Cut Pro 7 - Change the speed to the entire timeline/sequence
André Santos
on Mar 14, 2011 at 1:16:11 pm
Hi.
Im a beginner at Final Cut Pro, i know how to change the speed of a clip but,
today i added in the sequence 2 clips, i added an inicial crossfade and a final clip crossfade... between each two clips, i applied a crossfade too. Then i rendered the crossfades...
Now, when i select the two clips, and apply the change speed to 3500% for example... Final Cut Pro
is changing just the first clip, the second one, stays intact in the same place..
How can i make the entire sequence (40minutes) have +/- 1m30s = +/- 3500% speed change forward ?
Jerry Hofmann
Re: Final Cut Pro 7 - Change the speed to the entire timeline/sequence
on Mar 14, 2011 at 3:23:17 pm
FCP can only change a single clip at a time. However you can export a sequence of clips as a self contained movie, reimport it, and then apply a speed change to the whole sequence.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Terry Mikkelsen
on Mar 14, 2011 at 5:37:12 pm
Also, if you nest the sequence into another sequence, then you can apply a speed adjustment to the entire sequence.
Tech-T Productions
http://www.technical-t.com
