BITC in fcp
dan crouch
BITC in fcp
on Mar 12, 2011 at 9:46:50 am
Very simple question...
Can fcp generate BITC.
I need to burn a dvd on my mac and can't find out if I can
make it with BITC.
Thanks in advance.
Dan.
Rafael Amador
Re: BITC in fcp
on Mar 12, 2011 at 10:39:38 am
There are two filters that will burn TC on the picture:
- TC reader; Will read the original TC of the clips on the sequence.
- TC Generator: Will generate a TC starting with the default 00;00;00;00 or the TC that you set.
If your time line has cuts and you want a continuous TC, nest the sequence and apply the TC Generator.
rafael
http://www.nagavideo.com
dan crouch
Re: BITC in fcp
on Mar 12, 2011 at 10:41:12 am
Awesome! thanks v much.
Dan.
