Boris 3D text jumping
Bob O'Brien
on Mar 11, 2011 at 11:29:29 pm
I have never had this problem in 8 years of using FCP. Thoughts?
I made a line of text in Boris 3D. When I render the clip and play back, everything is fine for a while, then suddenly the first letter disappears, for a frame, then comes back. This causes the entire line of text to shift back an forth.
This happens on more than one of my text clips. These clips have no keyframes.
I tried trashing preferences, repairing permissions, and even re-rendered the text. It still jumps (but at a different time though each time I render!).
Strange, huh? (I'm sure I'll be able to figure out a work-around - just wondered if you'd ever seen this).
Thanks.
-Bob
CAMERAS
Sony EX3, Sony DSR570 DVCAM, DXC637/PVV3 Betacam-SP
PORTABLE EDITING
*MacBook Pro - 2.33Ghz - 2Gb RAM
*Matrox MXO / 23" Cinema Display
DESKTOP
*8-Core Mac Pro, 6 Gb RAM, 2 internal eSata drives, FW800 externals
*AJA IO
*Sony 2800
SOFTWARE
*OSX10.4.11, QT 7.5, FCP 6.0.4, Livetype 2.1.3, Soundtrack Pro 2.0.2, DVDSP4.2.1, Adobe CS3 Prod Suite
Rafael Amador
Re: Boris 3D text jumping
on Mar 12, 2011 at 6:13:09 am
Try deleting the Boris Preferences.
On User/library/preferences, look for "com.borisfx..".
rafael
http://www.nagavideo.com
Bob O'Brien
on Mar 14, 2011 at 12:12:43 pm
Thanks Rafael! That did the trick. (Seems so obvious now. It's funny how in the heat of the battle sometimes you don't think so clearly).
-Bob O'Brien
