Workflow best practices
Harlen Mallis
on Mar 11, 2011 at 6:11:30 pm
The project is a clip reel comprised of 1 min clips that will be imported into a macbookpro with Keynote as 1920x1080i h.264 and projected onto a big screen in a theater. Someone else is doing that part of the process.
I have a variety of clips that I'm working with from a variety of sources both NTSC and PAL and DVD.
There is a mix of aspect ratios, 720x480 - 1920x1080 and everything in between and frame rates from 23.98 to 29.97.
I have been doing some tests processing the individual clips in Compressor to get them to 1080i 60. The test playback looks good. Is there a better way to be doing this? More efficient, better quality?
thanks
h
Harlen Mallis
Re: Workflow best practices
on Mar 11, 2011 at 7:44:52 pm
Added info. I did find out that I can deliver any frame rate. Would it be better to conform all of the different rates to 29.97. Delivered rates for raw clips are 23.98, 25 and 29.97.
thanks
h
