lowering image quality on render
Adam Clements
on Mar 10, 2011 at 12:41:00 pm
I am using a transition in my sequence to and from a still image and every time I render, the image resolution becomes very bad. looks great up until the render, and looks great if rendered without a transition - also the same thing happens when i use different transitions.
is this a render setting? or am i missing something else?
thanks,
adam
Thomas Morter-Laing
Re: lowering image quality on render
on Mar 10, 2011 at 1:29:13 pm
What are your sequence settings? What type of image? What size image?
:D
Tom Morter-Laing
Freelance Editor
Certified Apple Product Proffessional, 2010
http://www.depictproductions.co.uk
Sony Z5, with Rode NTG2.
iMac 27" intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
Andrew Rendell
on Mar 10, 2011 at 1:40:39 pm
Have you checked the Render Control settings in the User Preferences?
