FCP Viewer Window Lagging
Ellis Berman
on Mar 9, 2011 at 12:55:27 am
Hello everyone,
I'm running FCP 7.0.3 on Mac OSX 10.5.8, Processor: 2.16 GHz Intel Core 2 Duo.
I'm working with NTSC DV 720x480 footage and I'm having trouble with the viewer.
Whenever I play a clip in the viewer, it starts to lag. When I drag the clip into the timeline, it plays perfectly fine.
What is going on with the viewer?
Jerry Hofmann
Re: FCP Viewer Window Lagging
on Mar 9, 2011 at 2:28:59 pm
Not sure what's causeing this, but if you'll post more info, I'll bet we can figure it out...
Lagging, I presume, means it's dropping frames?
Post what you're using as a scratch disk for starters. Might just be the problem.
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog:
Current DVD:
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Ellis Berman
on Mar 9, 2011 at 5:56:54 pm
I'm using my iMac's built in hard drive.
Richard Lord
on Jan 14, 2013 at 4:42:22 am
Did you ever find a solution to this? When I place prores422 clips into the viewer window I get playback issues. It's only on the time that I get reasonable playback - but I certainly can't play much back in the viewer.
1080i prores422 format
Machine - 2.8 quad-core intel xeon, 12gb ram.
I've never had this issue before on any other mac pro.
© 2018 All Rights Reserved
