lower layer images change when effect layer applied
Chris Foley
on Mar 8, 2011 at 4:22:03 am
I have a shot on playing on v1. When I add an alpha imported title above it on v3, the v1 video changes frames (it plays video from a few seconds earlier on the same clip...)
It does not matter if things are rendered or not. Does not matter whether safe/unlimited, dynamic/hi/lo, etc...
Tried re-boot also...
Thanks for any tips!
-Chris
(long time Avid guy, newer to FCP)
Rafael Amador
Re: lower layer images change when effect layer applied
on Mar 8, 2011 at 12:48:02 pm
What kind of stuff do you have on layer 1?
rafael
http://www.nagavideo.com
Chris Foley
on Mar 8, 2011 at 3:41:23 pm
just some HD video...
i have noticed sometimes when there is more than 1 layer in FCP, effects start to go wonky like this. I have seen dissolves that are dissolving from a different part of the clip than what is adjacent to them (so the last frame of the dissolve is a jump cut)
Rafael Amador
on Mar 9, 2011 at 1:54:25 am
[Chris Foley] "just some HD video..."
Do you have any problem to specify which kind of HD video?
That sounds to "some kind of video that shouldn't be there'.
rafael
Chris Foley
on Mar 9, 2011 at 10:17:03 pm
i examined it more closely - here is what it is doing exactly:
when the v2 alpha-title effect is applied, it makes v1 go 6 seconds and 25 frames earlier...
