Making image sequence for DCP
nick avaliani
on Mar 7, 2011 at 2:33:42 pm
Hello I have to deliver image sequence tiffs
So what I am doing is, I have quicktime self contained setting written video. But it is 1920X1080, I must make 2048X1080 of tiffs.
So What I am doing I am importing in FCP and changing sequence settings to custom 2048X1080, So I am getting black lines on the right and left side, I cover this black lines with matte color.
So my question is. DO I HAVE TO RENDER THIS VIDEO AGAIN? AND THEN EXPORT IMAGE SEQUENCE? WHAT IF I DO NOT RENDER AND EXPORT IMAGE SEQUENCE RIGHT AWAY. THE MAIN VIDEO IS RENDERED, JUST MATTE NEEDS RENDER BUT HOWEVER IT TAKES UP TO 4 HOURS SO IF I DO NOT RENDER AND EXPORT SEQUENCE WILL I HAVE PROBLEMS WITH DCP CREATOR?
Rafael Amador
Re: Making image sequence for DCP
on Mar 7, 2011 at 3:14:57 pm
You can render and export at the same time.
Try QT Conversion > Still Sequence.
rafael
http://www.nagavideo.com
nick avaliani
on Mar 7, 2011 at 3:22:48 pm
I am new to this it is not so easy for me, qt conversion still images? what is difference from tiffs? or how can I do this to render and export at the same time?
Chris Tompkins
on Mar 7, 2011 at 3:29:43 pm
The "Quicktime conversions" menu (Export)is where you select image sequence.
Chris Tompkins
Video Atlanta LLC
