Importing problems
Michelle Orpe
Importing problems
on Mar 3, 2011 at 4:32:40 pm
I'm doing some editing, I've imported all the clips I want into FCP but most of it isn't playing in the viewer, it jumps and stutters or just freezes while the audio carry's on. I tried dropping it onto the timeline (it asked if I wanted to match it) and then rendering it but when I played it nothing had changed and it was mainly playing the audio but the video is frozen or jumpy or just black. When I double click these clips in the desktop they play no problem, but once I have imported them into FCP they won't play properly.
I have 3 clips that won't work, one of them is an mp4 so I tried converting it to .mov and then dropping it in and trying it but no luck, the other two are h.264. I'll write the settings for my sequence and the clips below:
Sequence:
Frame Size: 764 x 574
Aspect Ratio: Custom
Pixel Aspect Ratio: Square
Field Dominance: Nonce
Editing timebase: 25
Quicktime Video Settings: Compresser: H.264
Audio Settings: Rate: 48 KHZ
Depth: 16-Bit
Config: Channel Grouped
Clip 1
Creator: Quicktime Player
Tracks: 1V2A
Vid Rate: 25 fps
Frame Size: 751x564
Compressor: H.264
Data Rate: 202.5 K/sec
Pixel Apect: Square
Field Dominance: None
Alpha: None/Ignore
Composite: Normal
Audio: 1 Stereo
Aud Rate 48 Khz
Aud Format: 32'bit Floating Point
Clip 2
Tracks: 1V2A
Vid Rate: 23.98
Frame Size: 1920x1080
Compressor: H.264
Data Rate: 8.0MB/sec
Pixel Apect: Square
Alpha: None/Ignore
Composite: Normal
Audio: 1 Stereo
Aud Rate 48 Khz
Clip 3 (I have this on DVD and used Handbrake to get it onto my mac)
Creator: itunes
Tracks: 1V2A
Vid Rate: 25 fps
Frame Size: 768x576
Compressor: H.264
Data Rate: 119.8 K/sec
Pixel Apect: PAL - CCIR 601
Alpha: None/Ignore
Composite: Normal
Audio: 1 Stereo
Aud Rate 48 Khz
Any idea's would be FAB :-)
Mich
Michelle Orpe
http://www.michelleorpe.com
Zane Barker
Re: Importing problems
on Mar 3, 2011 at 6:16:42 pm
H.264 is NOT a editing codec you need to convert the video to a proper editing codec before bringing them into FCP.
The cow forums are full of posts on this. Please search them!
**Hindsight is always 1080p**
Michelle Orpe
on Mar 3, 2011 at 6:30:20 pm
Hi Zane
Thanks for your reply, I've only just joined and I'm useless on forums, you said that the forums are full of threads about this, I did look and couldn't find any but what I did was write 'problems with importing' in the search and lots of things came up which were no good to me, I read quite a few which were completely different problems and thought there must be an easier way.
Any tips on how to use this forum as I have a feeling I shall be on here quite a lot lol
Cheers,
Michelle
Michelle Orpe
Zane Barker
on Mar 3, 2011 at 6:38:43 pm
If all you typed in wa importing provide im not surprised you didn't find an answer.
Your problem is not an importing problem it is a h.264 editing problem.
Surch that and you will find plenty of info. In fact there is another post just a few threads down relating to h.264 eding. It comes up multiple times a day.
Michelle Orpe
on Mar 3, 2011 at 6:46:58 pm
Ahh see it's easy when you know what to look for, before you told me I had no idea it was an H.624 problem I just couldn't get the footage to work.
Michelle Orpe
Andrew Rendell
+1
ProRes is the codec of choice for FCP.
Clip 2 is High Def (HD), whereas the others are Standard Def (SD) so unless you're actually making something in HD, I'd change that one to SD at the same time as changing the codec (it'll take a little longer to convert but it'll save time later).
P.S. I love the typo "Field Dominance: Nonce" - ROFL for obscure technical nerdiness reason (don't worry about it).
Michelle Orpe
on Mar 3, 2011 at 6:42:21 pm
Thanks Andrew
It's all very confusing :-) but I'm getting there slowly. So should I change my settings on FCP to prores then?
What is the easiest way to change a clip from HD to SD, somebody emailed me about what to do with the clips above, I right clicked them in the browser and exported as quicktime conversion and for clip 1 & 3 I changed to DV-PAL with size: PAL 720 x 576 4:3 and I'm currently doing the same for Clip 2 but with the size dimention PAL 720 x 576 16:9
Clip 2 has still got an hour to go but the first 2 worked great woohoo, this 2nd clip is going to still be in HD though (did you work that out because the frame size is 1920x1080 instead of 751x564 & 768x576 like the other two? Is that how you tell? so what do I do with the HD clip or will it change it automatically if my sequence is set to SD?
Thank you so much for your help I really appreciate it
Mich
Michelle Orpe
Andrew Rendell
on Mar 3, 2011 at 7:03:51 pm
Yes indeed the frame size is the giveaway.
What will happen is when you put your first clip on the timeline, it will (probably) ask you whether you want to make the sequence settings the same as the clip settings. Assuming that your first clip is an SD one, click yes and you'll have an SD sequence. Then when you edit a clip from the HD material into it FCP will automatically resize it to fit, so it'll make it into SD.
N.B. SD can be either 4:3 or 16:9, so you'll have to decide which one of them you want your sequence to be, then whether you want black bars and the whole of the picture or crop to fill the frame for whicherver pics are the other shape.
