Quicktime timecode length not matching sequence timecode length
Derek Klein
on Mar 1, 2011 at 6:04:00 pm
Hi all,
Weird issue I came across today. We've been working on a television episode that has a combination of 23.98 footage and 29.97 (basically documentary interviews and archival). We edited the footage in a 29.97 drop-frame timeline (our deliverable requirement for broadcast) and timed everything out. However, when we go to export a reference quicktime, that quicktime is 1 second and 8 frames longer than the sequence. (Sequence length is 21:10:01 and the quicktime times out to 21:11:09).
Any thoughts? Thanks!
Dave LaRonde
Re: Quicktime timecode length not matching sequence timecode length
on Mar 1, 2011 at 10:02:55 pm
That's the kind of difference you'd expect to see in a program of that length with a drop frame/non drop frame mixup.
At the end of one hour, the difference is 3 seconds and 18 frames.
Dave LaRonde
Sr. Promotion Producer
