P2 to final cut pro issues
Sophie kostrowska
on Feb 27, 2011 at 3:58:12 am
I am editing on fcp 5 and have imported some footage from P2 shot at PAL 1440x1080 HD 25fps and dslr 1920x1080 HD 25fps.
Firstly the audio/video settings do not seem to have a dvcpro anamorphic 25 setting, am i doing something wrong?
secondly do you have advice on getting my footage to edit seemlessly together...as i have learnt my lesson about getting the perfect settings the hard way in the past
Thankyou :)
x
Chris Tompkins
Re: P2 to final cut pro issues
on Feb 27, 2011 at 1:48:15 pm
Your footage is HD, you should edit in HD.
Drop a clip from the P2 footage into a new emty sequence and let FCP set the sequence settings for you.
What did you bring the DSLR footage in as?
Chris Tompkins
Video Atlanta LLC
Sophie kostrowska
on Feb 27, 2011 at 2:15:40 pm
well basically i just did file > import p2 and for dslr i did file > import straight from my canon folder
only thing is the setting fcp had was dv-pal which i didnt think did HD? will it affect the quality by export time?
Sophie Confused
x
