text layer alters picture luminance
Jason Fisher-Jones
on Feb 24, 2011 at 3:32:27 pm
When I add a simple text layer, the brightness of the shot is reduced slightly. When the text cuts off, the shot gets lighter. What gives?
Michael Gissing
Re: text layer alters picture luminance
on Feb 24, 2011 at 11:32:25 pm
What are you using to generate the text layer? Is it FCP's text gen, Boris, Manifesto, a PSD from photoshop?, Motion?
Jason Fisher-Jones
on Feb 25, 2011 at 10:05:35 am
FCP text gen
Andy Mees
on Feb 25, 2011 at 10:35:08 am
And where are you judging the luminance shift ... in the Canvas window or on an External display, rendered or unrendered?
Jason Fisher-Jones
on Feb 25, 2011 at 5:36:24 pm
It appears in the final Quicktime render. But it's inconsistent, not always shifting despite exactly the same text effect being used. It's driving me nuts. (As is the way FCP is messing up my audio levels keyframes, but that's another post).
Rafael Amador
on Feb 25, 2011 at 12:26:00 pm
[Jason Fisher-Jones] "When I add a simple text layer, the brightness of the shot is reduced slightly. When the text cuts off, the shot gets lighter. What gives?"
The default white on the text RGB at 100%, so they are not "Broadcast legal".
You can set R-G-B = 235 (instead of the default 255), or low the transparency of the text a bit (this is what I normally do).
rafael
http://www.nagavideo.com
