Eye One display 2 HDMI calibration
blai graell
on Feb 23, 2011 at 8:39:44 pm
Hi, guys.
I've recently purchased an Eizo FX2131 monitor to use it as a reference video monitor for color grading connected to my Matrox MXO2 Mini. I want to calibrate it using my Eye One display 2 colorimeter, but the problem is that it's software is for DVI calibration and doesn't allow HDMI output. Does anyone know any software for MacOSX that allows me to calibrate my monitor via HDMI or any other solution to calibrate it correctly for color grading?
Thanks.
Tony Brittan
Re: Eye One display 2 HDMI calibration
on Feb 24, 2011 at 1:18:24 pm
MXO2 has calibration built in for HDMI, no? I have the full size MXO2 and it does. Works great!
Tony Brittan
Owner - Island Shore Productions
blai graell
on Feb 25, 2011 at 10:02:35 am
Thanks Toni.
Yes, it does. But that only works for calibrating the output signal from the Matrox. Not for calibrating the monitor. To adjust correctly the monitor you should adjust the parameters of the monitor, not the signal.
