Capturing directly to sequence
Tom Bucknall
on Feb 23, 2011 at 8:12:07 pm
Does anyone know of a way to capture video directly to an open FCP sequence?
Background: We are currently cutting a 60 min program with a lot graphics and as such we are laying the graphics on in a linear session. Basically we play the show onto two digibeta tapes, then using an edit controller and a BlackMagic Decklink we key the graphics from one tape to the other doing a video insert only.
I'm trying to cut the tapes out of the equation and possibly the edit controller so I'm wondering if by using a KI Pro and FCP it would be possible to mark an in and out point on a sequence and capture onto a second video track above the original from the KI Pro + graphics. Obviously the timecode on the KI Pro and the FCP sequence would be identical and I could achieve the same thing by Log and Capturing but I would rather have the captured clip fall straight onto the sequence rather than the editor have to line it up manually.
I've looked at Virtual VTR but at £599 I'd rather see if it's possible my way first.
Thanks.
John Pale
Re: Capturing directly to sequence
on Feb 23, 2011 at 8:22:15 pm
FCP does not have this feature. Avid does have it, but I have never used it.
Francois Jean
on Feb 24, 2011 at 1:05:40 am
There is away to do this using "open" quicktime files...
This is describe in TELESTREAM pipeline user guide, but I not shure if you can generate such files without a pipeline.
ZAP
Steve Eisen
on Feb 24, 2011 at 4:43:01 am
Check out ToolOnAir. You can drop your clips in the timeline while you are still capturing.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
