NXCAM SD MPEG problem
Gergo Szabo
on Feb 23, 2011 at 10:34:19 am
Hi There,
I have problem. I have an SD MPEG2 file and FCP 7.0.3 when I import the MPEG file to the FCP it doesn't see the audio tracks of the file (not even the QT). But when I import it to the MPEG Streamclit I can hear the audio tracks.
Do you have any idea what can be the problem?
Gergő
Steve Eisen
Re: NXCAM SD MPEG problem
on Feb 23, 2011 at 12:59:37 pm
Please read some of posts below and you will find out why.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Chris Tompkins
on Feb 23, 2011 at 2:31:25 pm
You can't edit Mpeg files in FCP.
Convert it in Mpeg Stream clip.
Export to DV50 or something.
Chris Tompkins
Video Atlanta LLC
Rafael Amador
on Feb 23, 2011 at 4:20:04 pm
[Gergo Szabo] "I have problem. I have an SD MPEG2 file and FCP 7.0.3 when I import the MPEG file to the FCP it doesn't see the audio tracks of the file (not even the QT). But when I import it to the MPEG Streamclit I can hear the audio tracks. "
Hi Gergo,
I don't know the NXCAM, but I guess that its records the audio as MP2-Layer1.
Is an embed audio format and FC (QT) can not read it.
[Chris Tompkins] "You can't edit Mpeg files in FCP."
Why?
IMX is MPEG-2.
HDV is MPEG-2.
XDCAM is MPEG-2.
No problem with MPEG-2 on FC.
rafael
http://www.nagavideo.com
Gergo Szabo
on Feb 24, 2011 at 10:40:15 am
I have made an stream info in MPEG streamclip.
The result:
Type: MPEG program stream
Duration: 0:01:00
Data Size: 66.38 MB
Bit Rate: 9.21 Mbps
Video Tracks:
224 MPEG-2, 720 × 576, 16:9, 25 fps, 9.10 Mbps, upper field first
Audio Tracks:
128 AC3 2/0, 48 kHz, 256 kbps
Stream Files:
M2U01046.MPG (66.38 MB)
Rafael Amador
on Feb 24, 2011 at 10:53:32 am
[Gergo Szabo] "Audio Tracks:128 AC3 2/0, 48 kHz, 256 kbps"
OK. The audio is AC3 (no MP2 as I thought) it could).
You need a component to let QT playing that kind of audio.
Try installing "Perian".
rafael
Gergo Szabo
on Feb 24, 2011 at 12:13:43 pm
I have installed Perian and It doesn't play the sound :S
Anybody ever used a SD NXCAM MPEG2 files in FCP. The Apple support sais FCP 7.0.3 can play the SD MPEG2 files.
Gergo Szabo
on Feb 24, 2011 at 12:26:08 pm
Here is the solution:
You have to copy all the folder tree of the memory card, and you can ingest the files with "Log and Transfer". It converts all the files to ProRes422.
