'general error' and 'out of memory' messages...
Adam Heayberd
on Feb 22, 2011 at 3:44:31 pm
I was working with a project in motion, which when exported to FCP and into the sequnece caused the 'general error' and 'out of memory' error signs.
I cant be out of memory, its a brand new mac tower with added RAM and a 4TB G-Speed es added to it as the scratch disc.
When I put in the original clips before the motion project, when prompted I changed the sequence settings to match the clip settings.
Should I have done that? Im not quite sure what the ideal Sequence settings should be and this is pretty demoralising given the workload I have :(
Anyone any suggestions?
Adam
Editor & Self Shooter in the UK
Michael Gissing
Re: 'general error' and 'out of memory' messages...
on Feb 22, 2011 at 9:06:39 pm
There are lots of reasons behind the "out of memory" error message and a search of this forum will explain many of them. There have also been lots of posts about problems and instability in using Motion templates and round tripping.
John Doggett-Williams
on Feb 22, 2011 at 11:32:21 pm
Yes this subject has been tackled many times on these forums - the culprit in my case is usually oversize stills
John doggett-williams
Paul Jay
on Feb 23, 2011 at 9:05:05 am
Did you save the Motion project and imported it in FCP?
or
Did you export a quicktime movie from Motion?
or
Did you send a clip from FCP to Motion and then hit save?
Adam Heayberd
on Feb 23, 2011 at 9:30:08 am
I did both the first 2 options.
Paul Jay
on Feb 23, 2011 at 11:11:49 am
With the first option you always will have to render that in FCP.
Motion 3 always exports a quicktime Animation file , if you don't change export settings
Motion 4 always exports a ProRes 4444 file , if you don't change the export settings.
What are your current Sequence settings in FCP?
What are the properties (size, codec ) of your created Quicktime movie from Motion.
