B-roll contact sheet for each reel
Dan McGuire
on Feb 20, 2011 at 2:09:47 pm
This is more a general edit question -
I think it would make life much easier in the edit room to be able to consult a "contact sheet" of a particular reel - one 8.5x11 sheet that contains stills from a particular reel of footage - 1.5 inch thumbnails - perhaps 30 on a page - screen captured every 60 seconds or so, which would give me, at a glance, an idea of what is on the reel.
Quicktime allows me to output an image sequence at one shot per second, but I need to output roughly one frame per minute. Then I will bring the stills into Iphoto and create a contact sheet. Is there an easy way to do this?
Thanks in advance.
DMCG
Rafael Amador
Re: B-roll contact sheet for each reel
on Feb 20, 2011 at 2:20:37 pm
[Dan McGuire] "Quicktime allows me to output an image sequence at one shot per second, but I need to output roughly one frame per minute"
If you speed up the clip a 1800% (1440% if the footage is 24fps or 1500% if PAL) before exporting the still sequence, you get an still per minute.
rafael
http://www.nagavideo.com
Dan McGuire
on Feb 20, 2011 at 2:39:42 pm
It works, but the images are weird - interlaced? It seems to be a double exposure of 2-3 frames, so they are very blurred.
Tried to output them as jpegs and tiffs, but same results.
thanks
DAN
Jeremy Garchow
on Feb 20, 2011 at 2:44:53 pm
Turn off "frame blending" when adjusting the speed (command-j).
Rafael Amador
on Feb 21, 2011 at 4:31:30 am
[Dan McGuire] "It works, but the images are weird - interlaced? It seems to be a double exposure of 2-3 frames, so they are very blurred"
If the footage is Interlaced, of course the stills will show the interlacing.
You may nest the speeded-up clip , drop an de-interlacer and set the sequence to NONE.
rafael
Steve Eisen
on Feb 20, 2011 at 3:38:29 pm
View Browser items as large thumbnails and fill your screen (you can also set the poster frame). Use Grab to take a picture of your screen.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Mark Raudonis
on Feb 20, 2011 at 6:10:48 pm
Or get "CATdv". There's a forum for it here on the cow.
I keep one screen open in CATdv, and the other with FCP. I can search the whole universe of
my media MUCH easier than I could in FCP. (Thumbnails and all).
Try it. You'll see.
Mark
